BLOG
Introducing RapidGCode
September 22, 2021
A G-Code interpolator and UI. The G-Code interpolator is also accessible through the RapidCode API. Simple applications can use the UI to reach production quickly.
RapidGCode
A G-Code interpolator and UI. The G-Code interpolator is also accessible through the RapidCode API. The RapidCode API enables OEMs to easily add to their custom UI. Simple applications can use the UI to reach production quickly. We use RMP Motion Controller in the back-end to guarantee real-time deterministic performance.
OVERVIEWG-Code is a programming language for specifying coordinated motions in cartesian space used by many manufacturing machines. The RMP soft motion controller has the ability to parse and plan 3D coordinated motions based on the G-Code syntax. This allows for easy adoption of our controller if you are already familiar with G-Code.
Current RapidCode user using RMP
Leverage new cartesian coordinated motions without the need to calculate and manage trajectory points for streaming motion.
HMI/UI
Build your own user interface with our API functions or get up and running quickly with our G-Code UI for Rapid Setup.
Machine builder
Great for modernizing controls on systems that already use G-Code.
More than just GCode
Add other axes to do simple Point-to-Point or Streaming motion. Also add, IOs for added functionality.
On this page
