Beckhoff
EK and BK Series I/O Bus Couplers and its Terminals
Manufacturer:
Beckhoff
Node Type:
I/O Nodes
Input Voltage:
No items found.
Output Current:
No items found.
Country of Origin:
Germany
Special Features:
No items found.
The EtherCAT Couplers are the link between the EtherCAT protocol at fieldbus level and the EtherCAT Terminals. Since communication in the EtherCAT system is continuous through to the last terminal, the coupler only converts the physical layer without changing the process data stream.
