JVL
MAC400 Integrated Servo Drive and Motor
Manufacturer:
JVL
Node Type:
Input Voltage:
Output Current:
200-400 Amps
Country of Origin:
Denmark
Special Features:
EtherCAT
- The complete solution for medium power ratings. With built-in mains power supply.
- Choose between models with or without brake.
- Also in the IP66 version. Choose the Expansion module from the extensive selection for any application.
Features
- Absolute multiturn encoder without battery
- Real-time industrial Ethernet: Profinet, Ethernet/IP, MODBUS TCP, EtherCAT, Powerlink and SercosIII
- 2 RS422 channels for the encoder in/output and SSI encoder etc.
- 6IO for capture of position, interrupt, counters, enable, timer, and PLC functions
Expansion Module
- Basic Modules
- Programmable Modules
- Field Bus Modules
- High-Speed Multi-Axis Modules
- Wireless Modules
