Glentek
Glentek SMX9GE15 Gamma
Glentek SMX9GE15 Gamma from Glentek — tested for compatibility with the RMP EtherCAT Motion Controller.
Manufacturer
Glentek
SubDevice Type
Input Voltage
24-90 VDC, 90+ VDC, 100-240 VAC, 240-480 VAC
Output Current
1-6 Amps, 7-24 Amps, 25-72 Amps
Country of Origin
USA
Special Features
Customizable, Modular
Glentek servo drive with front connectors and terminal block for motor control
Three finned industrial control enclosures with cooling fans and green connectors on a red background
Key Benefits
Performance
FOC: All Gamma Series employ Field Oriented Control method which allows accurate control in both steady state or transient operation, and optimal orientation of the magnetic field.
Space Vector Modulation: Glentek’s advanced algorithms allow for maximum utilization of the DC bus voltage while generating minimum harmonic distortion of the currents in the winding of 3-phase AC motor.
Digital Current Loops: Current loop bandwidths up to 5 kHz.
DC Sync Rate: as fast as 125µs.
Digitally Tuned: All parameters set digitally. No potentiometers to adjust. DSP control for the ultimate in high performance.
Parametric Filtering: Provides control engineers advanced filtering to eliminate unwanted system mechanical resonance.
Smart-Comm Initialization: Eliminates the need for Hall sensor or commutation tracks for many applications.
Auto Phase Finding: Plug and Play for all types of three phase brushless motors. The drives algorithm will automatically find and align the motor phases.
Auto Phase Advance: Glentek’s advanced algorithms incorporated in the Gamma Series drives, automatically provide phase advance, insuring that the current is delivered at the appropriate time, and provides the most efficient operation.
Sinusoidal Commutation: For the ultimate in efficiency and smooth motion. Commutates from almost any resolution linear or rotary encoder or Hall sensors only.
Fault protection: Short from output to output, short from output to ground, drive RMS over current, drive under/over voltage, drive over temperature, motor over temperature.
On-the-fly mode switching: This feature allows the drive to switch between any mode of operation on-the-fly.
Software configurable: Glentek’s Windows™ based MotionMaestro© software provides ease of set-up, monitoring and tuning with no previous programming experience required.
Silent operation: 25 kHz PWM standard.
Feedback
Encoder feedback: Accepts quadrature encoder signals up to 5 MHz (maximum frequency of up to 10 MHz is possible, but is system dependent). Absolute serial encoder (Biss, EnDat, and T-Format). Analog Sin/Cos encoder.
Encoder Output Divider: The encoder input signal can be divided by a user selectable integer for the encoder output signal. Note: Available upon request only.
Resolver feedback: For resolver feedback the drive creates a simulated encoder output with a typical resolution of 12 bits.
Tachometer feedback: Accepts analog signals from all types of tachometer feedback.
Learn More on Glentek.com
RMP — The PC-based EtherCAT Motion Controller
Learn about our PC-based motion controller to use with this SubDevice.
Explore the RMP →
