Technosoft
iPOS8015 Series DC Servo drives
- Intelligent, compact and freely programmable motor controller
- For brushless, DC brush and step motors
- Motor supply / logic supply / STO supply: 11 – 80 VDC / 9 – 36 VDC / 18-40VDC
- Output current: 15 A RMS continuous; 28 A RMS peak current
- Communication via RS232 or EtherCAT
- STO inputs with safety integrity level SIL3/Cat3/PLe
- Size (L x W x H): 139 x 94.2 x 24.5 mm
Product Features
The iPOS8015 is a family of fully digital intelligent servo drives, based on the latest DSP technology and they offer unprecedented drive performance combined with an embedded motion controller.Programmable and flexible drive controller with integrated output stage, MotionChip ™ controller, I / O signals, EtherCAT interface, STO safety function and comprehensive support for motor technologies and encoder interfaces. The BZ module was specially developed for integration on a carrier board and offers an ideal solution for various applications with critical room conditions.
Electrical characteristics:
Motor supply / logic supply: 11 – 80 VDC / 9 – 36 VDC
Output current: 21 A continuous, 43 A peak current
Motor types:
Brushless DC motors (BLDC, PMSM motors)
Brushed DC motors (DC motors)
Stepper motors (2- or 3-phase)
Voice coil actuators
Linear motors
Feedback options:
1st Feedback:
Incremental encoder
SinCos 1Vpp
Digital Hall-sensors
Analog Hall-sensors
2nd Feedback:
Incremental encoder
SSI / BiSS-C
Panasonic
Tamagawa
Nikon
Sanyo Denki
EnDat 2.2
Control:
Via EtherCAT Bus, pulse and direction or analog/digital inputs
Autonomous execution of complex motion sequences stored in the nonvolatile memory of the drive.
Communication:
RS232 – up to 115 Kbit/s
EtherCAT – supports the following protocols with cycle times down to 10 kHz (100 µs):
CANopen over EtherCAT (CoE)
File over EtherCAT (FoE) enables the transfer of setup data and firmware updates.
Ethernet over EtherCAT (EoE), EasyMotion Studio enables communication with the iPOS controller via Technosoft own protocol.
Digital and analog inputs/outputs:
4 digital inputs: 12-36 V, PNP/NPN programmable
4 digital outputs: 5-36 V, 0.5 A, PNP/NPN programmable
2 analog input: 12 bit, 12 bit, +/-10V and 0-5V: Reference and Feedback (for Tacho) or general purpose
Possibility to use a digital output for controlling an external motor/holding brake
Integrated brake chopper function for controlling an external braking resistor
Safety:
Protection against over-current, over-temperature, under-voltage and over-voltage, I2t and following error.
STO – Safe Torque Off with safety integrity level SIL 3, category 3, PLe.
Control features:
Sinusoidal commutation with field-oriented control (FOC) via encoder, Hall sensors or sensorless.
Fast and accurate control loop structure with customizable sampling rate and PWM frequency up to 100KHz
Outstanding resonance and vibration suppression through the flexible, simultaneous use of 2 BiQuad filters.
Gain scheduling for dynamic adjustment of the PID controller parameters for optimal positioning performance.
Dual loop with simultaneous evaluation of two different feedback sensors to compensate for gear backlash and mechanical elasticities.
Closed-loop with sinusoidal commutation and field-oriented control (FOC) when encoder available.
Open loop with up to 512 microsteps per full step, step loss detection and automatic position compensation when encoder available on the load.
Operating modes:
Position, speed and torque control
Path generator with trapezoidal and sinusoidal ramps
Profile Position Mode, Velocity Mode, Homing Mode
Interpolated position with linear (PT) and cubic splines (PVT)
Cyclic Synchronous Position (CSP), Velocity (CSV), Torque (CST)
Electronic gears (EGEAR) and cams (ECAM)
Motion contouring via position, speed, torque or voltage
Analogue external reference, pulse and direction
EasyMotion Studio-Software:
Graphic programming interface with many functions and wizards for simple commissioning, configuration and local programming of complex sequence programs in single-axis or multi-axis systems.
Enables the selection of motor type, encoder interface and control structure as well as the setting of protection and controller parameters.
Automatic determination of the PID controller parameters (autotuning).
Extended analysis and optimization tools integrated using the control panels, loggers and scope functionalities.
Technosoft Motion Language (TML) programming language: Using the TML language, different operating modes, movement profiles, reference runs or the control of complex sequence programs can be graphically programmed and executed autonomously. The drive controllers can process analog and digital I / O signals, perform arithmetic and logical operations, and also exchange data and commands between the axes. Single-axis and multi-axis stand-alone applications can be easily implemented with self-created sequence programs, even without the use of a complex CANopen or EtherCAT master controller.
MotionChip ™ technology: The main core of all Technosoft servo controllers is the MotionChip ™ – an intelligent, freely programmable motion controller specially designed for complex motion control tasks. The MotionChip ™ offers the possibility to use the powerful digital signal processors (DSP) from Texas Instruments as an independent, intelligent unit. As a result, many tasks of a complex master control are solved directly by the MotionChip ™, so that the global function of a machine is relieved and the management of a master application can be optimized. All-important control functions of a controller such as a multitude of operating modes, PLC properties, protection and safety functions as well as support for the different interface and motor technologies are accommodated on the MotionChip ™, thus enabling flexible use in a wide variety of drive systems.
Product Details
- Supply Voltage:
- Output Current – Nominal:
- 15A RMS
- Continuous/Peak Current:
- 21/40 A
- Communication:
- RS-232,EtherCAT
- Controlled Motors:
- DC Brushless,DC Brushed,Linear,Stepper,Voice Coil
- Sensors:
- Incremental,1Vpp Sin/Cos,SSI,BISS-C,EnDat 2.2,Digital Halls,Analog Halls,Tacho,Sensorless,Panasonic,TAMAGAWA,Nikon,Sanyo Denki
- Motion Control:
- Control Functions (Position-Speed-Torque),Electronic Gearing,Electronic Camming
- Digital Inputs: 4
- Digital Outputs: 4
- Analog Inputs: 2
