LS Electric
LS Electric - iX7NH
Manufacturer:
LS Electric
Node Type:
Input Voltage:
No items found.
Output Current:
1-6 Amps
7-24 Amps
Country of Origin:
South Korea
Special Features:
No items found.
Compact Size & Convenient Installation
- Zero-stack installation space achieved through highly efficient heat dissipation
- 100W ~ 1kW Drive
- Minimized drive depth for 100W and 200W drives through development and application of smaller heat sinks
- 172.5mm → 145.2mm ; volume reduced by 16%
- Easy-to-open parameter display cover
- Spring clamp connector applied for easier wiring
Enhanced Encoder & Control Functions
- More types of encoders supported on top of high resolution encoder
- BiSS, Quadrature, Tamagawa, Panasonic, EnDat 2.2, SSI, Nikon and Sinusoidal (Optional)
- Supports temperature monitoring through encoders
- Enhanced disconnection check function of quadrature encoder
- Disconnection check circuit added
- No dummy wiring needed
- Improved control cycle
- Position: 125 μs
- Speed: 62.5 μs
- Current: 31.25 μs
- Enhanced alarm trace function
- Capable of saving up to 4 channels such as alarm code & alarm occurrence time/date
- Enhanced USB OTG(On-The-Go) function
- Drive parameter backup on USB thumb drives (Drive → USB flash drive)
- Drive parameter restoration from USB thumb drives (Drive ← USB flash drive)
- Drive alarm history backup (Drive → USB flash drive)
- Firmware update (Drive ← USB flash drive)
- Added buttons for user convenience
Faster Communication Provided in More Diverse Methods
- Fieldbus Supported: EtherCAT
- Min. Communication Cycle Time: 0.125ms
- Advanced EtherCAT function
- Minimum communication cycle time improved from 0.125 ms to 0.250 ms
- FoE function supported
- Built-in web server function
- With web server embedded in servo drive, no drive CM
(Configuration software) is needed other than web browser environment - Enhanced remote commissioning function through Ethernet connection
