New
- RapidSetupX Tool for Windows, Linux, & MacOS. (Beta)
- RMP firmware - MathBlocks for real-time math and bit-masking operations.
- RapidServer - NetworkNode Digital and Analog I/O data types updated.
- RapidCodeRemote - MultiAxis new actions map, unmap. New status is_mapped. Config set with axes_indices will AxisRemoveAll() first.
Change
- RapidCode - Objects upgraded to global, named locks for interprocess synchronization and safety.
- Cartesian Robot - PathState returns Idle if/when joints are moved directly.
- RapidCodeRemote - MultiAxis Status amp_enabled and Motion parameters renamed.
Fix
- RapidCode - Default values for Axis now retrieved from RMP memory for multi-process consistency.
- RapidCodeRemote - RapidServer no longer recreates RapidCode object on MotionControllerConfigGet.
- Linux - RMPNetwork no longer outputs argument help when started via RapidCode.
- Linux/rsiconfig - default path separator for Axis XML files.
